help with 993 dme (varioram) transplant
got stuck today with wiring the dme to the car, hope somebody has an idea what to do.
my car is 1989, just intalled a 1997 993 motor in it and a 95 dme (with vario chip), all went smooth till I got to connect the 993 wiring harness to the connectors under the seat. the problem is one of the connectors looks different. here's couple of pictures of what I'm talking about:
in the first picture is the 964 connectors under the seat and the second are the ones from the new dme. Thank's.
Email info@speedservice.nl
Olav did a 993 engine into 964 turbo and the dme did not work so had to revert to the 964 ECU. He'll give you the details if you ask nicely.
