964 Forum 1989-1994
Calibrating the speedo
Old Nov 25, 2010 | 09:29 AM
John Boggiano's Avatar
John Boggiano
Lifetime Member
Default Calibrating the speedo
Thought it worth a new thread for this, even though it's also tagged on the end of the thread about the odometer problem.
I should have done this years ago! I've put up with an adrift speedo reading for years and years, then found a company that would recalibrate it for about £65. Then I thought 'Oh for heaven's sake - how hard can it be?!'
Pretty easy to do - I gave the needle a 'guess twist' on the work table, but then put the speedo back in the car without its glass to tweak it against a GPS while out and about.
I now have a 2mph error at 20mph, 1 at 30, then it is spot on at 40, 50, 60, 70, 80 and 90. Very pleased.
A little tricky taking off and refitting the glass - one of those jobs that would be much easier if you'd done it before. There are little slots at the very top and bottom of the gauge, just under the crimped lip. If you can coax a small screwdriver blade into that to get you started, then you can just slip the blade around one half of the circumference, giving it a little wriggle as you go. Similar idea for getting it back together. Note: it is far easier to avoid touching the inside of the glass than it is to wipe any marks off afterwards - I recommend blowing it to remove any dust rather than wiping.
My speedo had a 5-6mph error, and the needle sat at rest on the first marking. Here's how it looks now.
File Type: jpg
Old Nov 25, 2010 | 10:19 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Nice job! I will have to disassemble my speedometer this winter. The odometer failed over the summer.
Old Nov 25, 2010 | 10:45 AM
John Boggiano
Lifetime Member
Here's a pic showing the uncrimping idea.
File Type: jpg
Old Nov 25, 2010 | 11:02 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
The photo helps visualize what you were describing. Thanks.
Old Nov 26, 2010 | 06:16 PM
Sten's Avatar
Sten
My speedo over reads - when it shows 80 I'm doing 70 according to my Sat Nav, and flat out chasing Mr.Boggiano up the Autobahn it read 180 while the Sat Nav said 162.
Old Nov 26, 2010 | 08:23 PM
gchristofi's Avatar
gchristofi
helps keep the points police away and the license clean ;-)
Old Feb 24, 2014 | 08:04 PM
hepkat63's Avatar
hepkat63
Has anyone tried John's idea on a 964 with Cruise control and LED (digital) readout computer as well? I guess I am wondering if you adjust the needle, will the LED read the same?
Old Feb 24, 2014 | 09:37 PM
jimq's Avatar
jimq
Burgled
it has nothing to do with the digital readout. All he did was move the needle position on the speedometer.
