Odd Alternator/Voltage Regulator/Battery Problem
#31
A failed regulator such that the alternator is never putting out will not over charge the battery , but it can let the battery be drained below a level that is harmful .
A failed regulator that overcharges a battery will cause problems to the battery .
If the replacement voltage regulator works , you will have saved yourself some work and dollars . If it does not do the trick you will be out some money and labor .
Thanks for the link but all I gathered was that it was a bad decision to disconnect the load (battery) from the alternator because of the potential of frying diodes. Still though, if the alternator was broken and the battery was disconnected wouldn't the car die? Would I be able to rule out the alternator being completely shot? I didn't see that covered in the link.
it was a link to show the steps to diode damage .
A "broken alternator" could be putting out enough electrons to keep some things running but not others .
#32
I was able to take it to a local auto shop today to get the alternator tested (at the battery) and the results were somewhat surprising. The test showed that the alternator diodes were good, the regulator was bad and that the charge was too low for charging the battery.
Taking your suggestion, where should I get the regulator from? Pelican is about $100 whereas other retailers are showing it for ~$25. Any recommendations? Since the alternator will be out In replacing the regulator I'll take it in to be bench tested and see if that should be replaced also. Decent approach to trouble shooting this next step?
#33
Getting the alternator / fan assembly tested off the car is interesting/difficult .
I would suggest you put the new voltage regulator on the alternator
and then put the alternator / fan assembly back on the engine .
And then test to see if the "whole" is happy .
#34
well I think that will be the next step. Is there a reason to buy a Bosch voltage regulator ($50) over a Kaehler voltage regulator ($25)? Those are the only two brands I can find to purchase. I would think that the original equipment would be Bosch and maybe there is a slight preference to Bosch because of that reason.
The rest of the trouble shooting will have to wait until the parts come in and I finish with my law school finals.....assuming I am still alive after them. Hopefully then I'll have time to pull the alternator and replace the VR and reinstall the alternator. There isnt a way to replace the regulator with the alternator still installed?
#35
Yes it definitely seems like a daunting task. Are there any special tools needed for the voltage regulator replacement? I shouldnt need the triple square (12 point) piece for the regulator right?
What about the choice between getting a bosch or kaehler? Worth double the price for getting bosch instead?
#37
You'll need the triple square bit to get the belts off which need to come off to remove the alternator. Then you'll have access to the front of the alternator where the VR resides. Consider replacing the complete alternator - the time and effort spent getting it out and back in untested is one thing. Buying a complete alternator that's been tested, has fresh bearings is worth the extra peace of mind.
If time is a constraint right now and you need the car, you can drive it approx. 80 miles without lights on with a fully charged battery and a non-functioning battery. But don't sue me if you only make it to 79 miles... good luck on your law exams!
Here's the DIY w/ pics of VR
http://www.pcarworkshop.com/index.ph...or_Replacement
Don't for get to disconnect the battery before starting this job!!
#38
It looks like the Kaehler might be ok . Made in Germany .
#39
http://translate.google.com/translat...GLL_en___US373
#40
If you have the tool kit , the tool should be in the kit .
This is what the tool looks like .
http://www.eagleday.com/fanbepunutto.html
#41
For some reason it didn't even cross my mind that the tool would be in the factory supplied kit. I still have all of the tools from the original purchase so it must be there. Again thanks for the invaluable information, I'll be ordering the voltage regulator along with some new engine lid struts tomorrow. Hopefully I can get some free time to do the replacement before too long.
#43
of course when i finally have time to work on the charging system I come to find out that the previous owner/mechanic has completely stripped out the shaft where the twelve point tool is supposed to go into. I have the tool, M10 twelve pointer, but the hole has been stripped. I am assuming they tried using a torx or allen set on it instead of the correct porsche tool. What do you think my next step should be? Try using a different tool to hold it in place or take it to a shop to be taken care of by them?
At least I have other things to deal with like finding out why the vents are always blowing air through even with the ccu off and trying to remove all of the wiring from the prehistoric cell phone system installed originally.
#44
If you epoxy the tool into the hole , you might be able to get the pulley off and the fan off .
Another way might be to use a little shim stock inbetween the tool and the hole .
#45
i think i am going to try the epoxy approach but because the hole is so stripped and ruined I can only get a very small amount of the tool into the hole. I am not sure how much that is going to help, I did find out that an allen bit fits almost perfectly in the hole, that must be the tool used to get it off last time and the one that ruined the shaft.
