964 Forum 1989-1994
Why...
Old Nov 5, 2010 | 02:49 AM
Moffman's Avatar
Moffman
Default Why...
Oh why....
http://www.youtube.com/watch?v=k7IIx...eature=related
Old Nov 5, 2010 | 08:30 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
??? What am I missing?
Old Nov 5, 2010 | 09:35 AM
elbeee964's Avatar
elbeee964
This [below] easy-hp buttload of iron is an LS1; now residing in the tail of that (what, 3.2L?) Carrera.
(LS1 = chevy small block)
Old Nov 5, 2010 | 12:41 PM
PorscheZen's Avatar
PorscheZen
Better than the "fail" I thought was going to happen...
Old Nov 5, 2010 | 01:07 PM
Makmov's Avatar
Makmov
Actually it's a 5th Gen LS1 which is an Aluminum block.
Renagade Hybrids has made themselves a who industry out of coverting Porsche, not just 911s but 914s, 997s, 928s, 944 by putting LS1 in them. They claim it's more power, less drama, easier to drive, more cost effective, and better economy than what the Porsche factory built.
Old Nov 5, 2010 | 02:30 PM
tbennett017's Avatar
tbennett017
That's a pretty sweet first fire-up... I was expecting a lot more drama/cranking wow.
I don't think this is the travesty that some might... if you have a body with a bad engine... why not? Sounds cool.
Old Nov 5, 2010 | 03:02 PM
stinkydog's Avatar
stinkydog
The newer LS1 motors weigh less than a 964's 3.6 (around 480lbs stock versus 510). Not sure of the weight differences between transmissions & cooling systems though, and the center of gravity of the LS1 is probably high enough to negate the advantage of its lower weight.
Old Nov 5, 2010 | 03:11 PM
J richard's Avatar
J richard
There used to be a guy here years ago, george 911-v8 always a hilarious exchange about the "purist" vs the "real" car guy... In my mind the engine is what makes a Porsche what it is... If you need to jamb a big engine in something to go fast it's in the wrong place, better off with a vette...
7 Porsche Models That Have Aged Like Fine Wine
Old Nov 5, 2010 | 04:37 PM
elbeee964's Avatar
elbeee964
Pretty sure LS1's were Gen.-III. Most likely the guy's running an aluminum block, though LS1's also came in the iron flavor (for the truck crowd.) I'm not cognizant of the tells in telling the two apart, but somebody LS1-smart may be able to ID it as aluminum from the guy's video.
If there's a better way to make a 911 scoot around a track, I'm fairly sure more folks would be 'hybriding'.
I've got this sneaking suspicion that wet-sump + higher CG make for a less track-friendly rig.
But I see plenty of straight-line blvd romps and parking lot cookies in their advertising!
The drag racing crowd likely gets a kick out of these hybrids. (Though I doubt the 915 trannys do...)
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
