Problem at idle [help needed]
Just to back step a bit, was anything changed or worked on prior to the problem appearing? Have you checked your spark plug wires? How old are they? A light misting of water from a spray bottle while in the dark around coil/spark plug wires may illuminate the problem? If that doesn't uncover anything, try removing the spark plugs for inspection. They are the window into your engine and how it is running. They should all be a dry and tan in colour.
You say "No vacuum leaks". How did you check this?
Pull up a deckchair to the back of the car. Open the engine lid. Open a beer. With a screwdriver carefully tighten every jubilee clip on the inlet manifold half a turn - look all around the engine bay - if you see a clip tighten it to take up any slack. Not too tight - just half a turn to stop any leaks (especially if your mechanics replaced tubes/pipes/hoses last year). Your symptoms sound like a classic vacuum/intake air leak. Once you do this it's one thing we can tick off the list.
Last weekend I did that, I put off the ISV, I cleaned the idle speed control valve.. And I took a look of this tubes But this afternoon I will tight them more carefully..!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Thanks guys! I will tell you afterwards.!
Good luck.
Interesting thread to me as my idle does tend to cycle up and down between 500 and 1000. i also get a slight knocking sound at times in first gear when pulling away from a stop.
1 Post
I checked my idle switch, it does "click" when it closes.. so... 02 Sensor 100%?
When I start it sometimes do a backfire.. I think that only can be the 02 sensor, because my idle switch is OK, y cleaned the idle regulator.. and my distributor belt is fine.. so.¿could be a rotor or a cap distributor? I think no but I have yo ask..
Regards!
Regards!
