Ac fan belt slips
After 6 years of not running my ac, I decided to hook it back up today. It was about that long ago that I switched it over from r12 to freeze, but ran into a problem back then, so I just pulled the belt, and have enjoyed just cruising with the windows down (and a few extra HP). I can't remember that I ever used the ac when it was r12.
The issue back then and now, is that when I accelerate over 4000 rpm I feel a strong shuttering. I was thinking it was the belt slipping but I do not smell burnt rubber. The system seems to cool just fine under 4000 rpm, but who likes driving that way? Tightening the belt to an unreasonable level does not change things (ie: it is not a belt tightening issue)
Is the ac clutch suppose to turn off upon acceleration, or does this sound like a bad ac clutch or compressor?
Tom
Tom
IHI KING!
Did you check the tension on the AC belt? Its adjustable via a bolt under the compressor. Its not easily seen but you can feel it. Its a standard 8mm bolt with a stop nut. You loosen the nut and tighten the bolt to tighten the belt.
