Replacement for Plastic Nut and Push Button
I am looking for replacement body parts.
The first is the plastic nuts that hold the plate that goes over the brake servo. P/N is 999 049 012 40
The second is the plastic push button that holds the rear seat side panel. P/N is 90 068 501
Are there commercial substitutes for these parts. If so where can I find them.
Thanks guys
Thanks guys
Ditto getting factory parts for this replacement (esp. for so few pieces.)
However, you could spend quality time in McMaster-Carr's "nut" section. (It's just the time spent researching/finding/ordering vs. the likelihood of significant savings is pretty much nil.)
But when I needed a few dozen valve cover nuts [locking M6x1], M-C was where I went. I ordered their min. gross: a hundred (enough for nearly 3 valve jobs!) without breaking a $20!
Try doing that via Porsche's parts...
Of course, there's always Lowe's/Home Depot's 'Specialty' nut bins...
Who knows? Maybe you'll get lucky!
Thanks Rob and Lonnie,
I tried to get my local Porsche dealer to order them with no luck. My next best shot is via a dismantler, but they often don't want to deal with such small $ parts.
I have spent a bit of time in hardware stores., both plastic nuts mate to a sheet metal type of screw, not a standard SAE thread. McMasters-Carr approach is difficult, since I do not know the thread specs or what would work.
Joe Perret
joeperret@msn.com
Joe Perret
joeperret@msn.com
They are only pennies each, and theres no valid reason you dealer cant order them (indeed I'm amazed they havent got them on the shelf as they fit a number of models and locations) I ordered the brake cover ones a couple of months ago without problem
IHI KING!
Try a different dealer. I have ordered very small items through EBS Racing and they have been able to get everything I needed so far. Others speak highly of Sunset Porsche.
No affiliations.
No affiliations.
