DME Relay and Oil Level
So yesterday evening I got into the car and started her up. Then I realized I had forgotten to put the top down, so I stopped the engine and lowered the top (stupid design not being able to raise/lower the top while the engine is running). Anyways, after lowering the top the car would not start, just crank and crank. Of course I don’t have a spare DME Relay with me so I yank it and shake it. After numerous iterations of this and cranking and cranking, magically she starts and runs beautifully as she always does.
However, I noticed that after she warmed up, my oil level wasn’t as high as it normally is or what it was in the morning. Does anyone have any ideas as to why cranking the engine on/off for a while or the DME Relay problem would cause the oil level to show or be lower?
I don't have an issue with the top relay only working with the engine off at all, 15 sec. of your life in exchange for driving a drop-top Porsche, seems worth it to me.
The Oil level sensors in these cars are notoriously bad, and not to be trusted. Were you at idle? On level ground? Did you allow the engine to idle 30 sec. or more?
Most importantly, have you manually checked the oil level with the dipstick to be certain you haven't sprung a leak somewhere?
Cheers!
Cheers!
I can help You with that, here You are: https://rennlist.com/forums/964-foru...is-moving.html
Cheers!
Cheers!
If this isn't true, then I would perform this mod. I've owned numerous Cabrios and none of them required the engine to be off. I understand having to be stopped, but off is crazy. Why would Porsche even design it this way?
Burgled
I've read about this mod, but haven't performed it due to a number of articles on RL stating the warning lights for the top don't work properly after its implementation.
Yes, there is one problem.
Every time You start the engine, cabrio top control light stays on.
You have only to push the cabrio top button for close if is closed, or for open when top is opened and then control light fading.
Ofcourse You can to turn the bulb.
I guess you could say I want it to work as should've been designed.
