won't idle after cleaning ISV
I cleaned my isv with carb cleaner and now car won't idle, stalls each time I take my foot off the gas. I sprayed and allowed it to dry for about a half hour. I took it for about a 10 mile drive and still same results. I can say while disconnecting the electrical connection, the metal clip jumped off and I couldn't find it. Other than that I don't know what the problem could be. Also I noticed while cleaning, the inside of the valve doesn't spin. I saw a video where the inside of the isv spins. Mine seems to be locked up. Any ideas?
You can test it with a 9V battery, if it does not turn, try to clean it again. I don't know if carb cleaner is the best choice, but after cleaning you should be able to turn the cylinder with a screwdriver, but be careful not to scratch it. You mentioned a clip that jumped off, did you get that installed correctly?
I once fooled around in that rat's nest area and forgot to reconnect the ISV plug.
Sounded exactly as you describe.
Not saying that's the case, here, but...
Also, after cleaning the ISV with various spray-petrol cleaners my ISV's operation was a little balky at first. Perhaps yours, too?
And, lastly, rotating that inner valve barrel was the only way I was able to thoroughly/decidedly empty the ISV's innards of my spray-on cleaners.
There are some good threads in here about the ISV and cleaning it with the different outcomes. Just do a search for the ISV and cleaning; this should bring up a plethora of information. -D²
RL Technical Advisor
Hi,
You need to get a magnet and find that metal clip for the connector!!!
First, you may have installed the ISV backwards,.......(its been done)
Second, this is a servo motor so it doesn't actually rotate or spin 360 degrees; it simply moves 90 degrees to open and close, allowing more or less air to bypass the throttle valves.
Make sure you have a solid electrical connection as that will create the symptoms you describe. That requires the wire to lock it together.
Make sure you do a DME reset. Your car was used to idling with a dirty ISV, now that it's clean it needs to adjust itself. Simplest way is to disconnect the earth strap at the battery for about a minute, reconnect, fire up the engine, let it idle for a five minutes and then go for a drive using most of the rev range through the gears.
I see PorscheZen beat me by a couple of minutes!
I think the issue is more with the missing clip causing a poor electrical connection. As Steve said, 'find it' and re-install. Cleaning the ICV should not cause the symptoms you are describing.
I did exactly the same thing.
- Removed ISV, metal spring shot away (I'll get that later methinks)
- Joyfully cleaned out all the crap with Carb cleaner
- Tested with 9v
- Reinstalled but forgot to reconnect the plug
- Started but no idle at all, fished around....cursed stupidity of not reconnecting plug...started and idled perfectly.
- Metal clip remains AWOL.
- Tested with 9v
ISV installed backwards
Not to revive a 5-year-old thread, but I thought someone might benefit from a dumb experience of mine. As Steve Weiner said in this thread, if you're stalling after you remove and reinstall your ISV or for any other matter where you're stalling while idling, then double check the direction of your ISV!!! I reinstalled mine backwards for days before I realized the problem. I tore everything apart and discovered that the ISV was installed in the wrong direction. Readjusted it, now the car once again purrs. I wish I had seen this post earlier, but I stumbled onto the answer myself through trial and error and I thought I would share.
This is a simple and quick check for those of you baffled as to why the car stalls while coming to a stop or while idling. I read countless posts on AFM issues, vacuum leaks, bad idle microswitches, bad dizzys and ignition wires, resonance flap malfunction, bad throttle cables, bad DME chips, DME relays, etc. before figuring this out.
