Distributor Vent Fix?
So I've owned my 964 (4th Porsche) for close to 6 mos., fixing up some minor items (ashtray, door stay, speakers, hood struts), but now I've gotten around to the engine compartment and while trying to sort out some screeching from the heater blower motor, I noticed that the distributor vent kit had only been half done. They actually popped off the "plate" on the distributor and fitted the distributor ventilation connector, but never bothered drilling the hole in the "downpipe" from the heater blower motor nor connecting the hose, so it's vented, but it vents directly into the engine bay. Any thoughts on whether or not to leave it in this condition? And if a fix is suggested, where's the best place pricewise to get the remaining necessary bits?
Agreed that the T fitting tied into the existing rear tailight ventilation hose is the purest approach. I bought a black T fitting at NAPA Auto Parts for about $2. Worked perfectly. A 5 mnute task. No need to drill holes.
Jon, sounds like you only have half the ventilation kit. Save yourself a lot of time and aggravation and spend a mere $13.50 and buy a complete Porsche kit from Pelican.
http://www.pelicanparts.com/cgi-bin/...(1989-8/93)%20
Dan
Dan
No kit required if you apply the T fitting. Just tie into the tailight vent set up. Measure the existing hose, cut where required, fit T fitting, reconnect as three sections of hose.
