Need a Screw...
Thought the title would get your attention
Do any of you guys know the size/thread of the 2 screws/bolts that holds down the plastic cover over the fan shroud? (the one covering the spark plug wires)
Mine never came with one when I bought it... I accquired one a couple of days ago... but it came with no mounting hardware.
Thanks in advance!
Thanks in advance!
I can't see it on PET. They are allen screws of around the size of M5 or M6 about 10mm long. You should be able to go to your local hardware store and get a couple different sizes and try them. I can take one out tonight, if someone else doesn't give you the answer.
Edit: Found it on PET but it doesn't list the size. Only the part number. 900-119-099-07.
