964 Forum 1989-1994
Strut Brace Design
Old Jul 19, 2010 | 04:23 AM
Unkle's Avatar
Unkle
Default Strut Brace Design
Hi,
I am looking at this
http://cgi.ebay.co.uk/ws/eBayISAPI.d...T#ht_720wt_911
A UK company are supplying them and it seems to have 2 possible advantages, it looks like it might fit under the carpet, and it secures at both sides of the top mount and not just the front fixings.
Does it seem like a good idea? I can't think of a reason why it would be a worse design than many others, as it might distribute the load across the complete area, but will listen to the knowledge of rennlist experts
Old Jul 19, 2010 | 06:16 AM
Computamedic's Avatar
Computamedic
I have the same model, bought from Simon when he was operating as Essential Styling. The strut brace is made by KLA Industries in the US (click here) and you might be able to save some $$$ if you buy from them direct.
It DOES fit under the carpet BTW.
Regards
Dave
Old Jul 19, 2010 | 07:03 AM
Unkle's Avatar
Unkle
Using the xe currency converter it work out about £5 cheaper from the US. Not bad but probably will go with the UK as it saves the hassle, but appreciate the suggestion.
What is it like? Is the quality good? Did you notice it?
Old Jul 19, 2010 | 08:00 AM
Harry Apps's Avatar
Harry Apps
I doubt that the larger mounts would make any difference for "normal" use and associated stress. The important bit is that the brace needs to be between the mounting points to prevent compression/stretch so the rear mount bolts appear to serve little purpose. I use a carbon fibre brace fitted to the front mounting points only and it easily fits under the carpet with no cutting.
Old Jul 19, 2010 | 05:43 PM
Unkle's Avatar
Unkle
Hi harry, where did you get your one from?
I'm not keen to cut the carpet TBH, but don't want to spend a load of cash on essentially a bar of metal or carbon
Old Jul 19, 2010 | 06:32 PM
Earlydays's Avatar
Earlydays
I have the Weltmeister strut brace and it also fits under the carpet.
Old Jul 20, 2010 | 05:12 AM
Harry Apps's Avatar
Harry Apps
Unkle
Can't remember now. I was fortunate to find an Ebay dealer who was clearing out stock - I bought two at low prices and later sold one on to recover all my costs!
H
