Problems with oil fan [need help,please]
Hi guys,
Mi oil fan didn't work so I bought in ebay two news resistors, when the come, I tested them with the polymer, the first one hadn't electricity continuity, but the second had,
I put of the original from my car and I put the one which has no continuity and the fan didn't work, and I change again the resistor and i put the one which has continuity, and it didn't work to
My fan it's OK, because if I do a bypass in the R04 relay(Blower relay) it works perfectly.
I think that my relay is in bad conditions, or could it be the "temperature sensor" which is located in the radiator?
And, another thing.. Which resistor I will have to leave, the one which has or not electricity continuity?
Regards
Regards
Ok, so in cold, my resistor wouldn't have electricity continuity, buy I taste with both of them, and fan didn't start :S, I don't know what can I do..:S
What is the function of the temperature sensor located in the radiator?. But is strange that my car has two problems, because my old resistor was broken, so... Is very strange that temperature sensor is broken..
Will I have to buy a brand new resistor? Could be the problem that ebay sealer cheat me?
