Changing Oil Resisto
Unable to remove the bolt that was holding the oil resistor in place even after the resitor broke into pieces. it seems that whatever is holding the nut on the other side is no longer in place, and the whole thing just turns, can move up and down but would not come out. Does this mean pulling the oil cooler, or is there another way to get to the nut?
Thanks as always for your feedback.
SOLVED: Could not remove from above only. Knowledge is key.
biggles
biggles
