964 Forum 1989-1994
condensor removal help
Old Jun 10, 2010 | 12:40 PM
Boeing 717's Avatar
Boeing 717
Registered User
Default condensor removal help
I am trying to remove the condensor from the left front wheel well. I can see at least 2 nuts holding it on, i think there are 3. Do i have to remove the front bumper to do this??? Please say no.
Old Jun 10, 2010 | 12:49 PM
altarchsa's Avatar
altarchsa
I didn't remove the front bumber when I removed the condenser on my car to replace the resistor type speed switch. It was a while back, so I can't remember the exact process, but I remember it was a real chore.
Keep at it and you'll get it. Good luck.
Old Jun 10, 2010 | 04:11 PM
Boeing 717's Avatar
Boeing 717
Registered User
Yea i got it, no bumper removal thank the lord. Man that thing was filthy, now its all clean and flushed out too. Thanks.
Old Jun 10, 2010 | 08:00 PM
oldskews4's Avatar
oldskews4
So were there 3 nuts? What did you do?
Old Jun 10, 2010 | 09:18 PM
Boeing 717's Avatar
Boeing 717
Registered User
Yea you have to remove the lower black panel under front bumper and then there are 3 nuts holding on a plate that the condensor sits on top of.
There are only 2 nuts holding the condensor to that plate.
Remove left bottom panel from bumper
Remove wheel
Remove wheel well liner
Disconnect the 3 clips for the wires and disconnect electrical socket to fan motor.
Disconnect the 2 AC hoses
Disconnect the water hose from the windshield washer tank
Remove the 2 nuts holding condensor onto that plate, one front in bumper also attached to a brace, one in wheel well
Remove 3 nuts on that plate and it should slide out the bottom
