Crooked Smile up front:(
Hey guys...
I'm happy a can be after getting my 965 a couple of months ago, and I have been tweaking it with a few things here and there... The 2 first pics shows the car when I got it, and the remaining ones are recent from a "repair" by a local shop who told me that the front spoiler has no way of being repaired any better?!?! This repair consisted of replacing the plastic mesh behind the spoiler, since the original one had plastic hooks that had sheared off (from PO's impact with something?). Anyhow, the new mesh didn't really change the symmetry of the spoiler and was hoping to see if there's a cure out there from one of you guys, or am I stuck with this until the entire front spoiler is replaced (not an option at this point!). I mean, even if it cannot be noticed, can't a metal plate or ? be installed around the spoiler beam to make it seem more straight? Thanks for the help - I know the pic's aren't that good and that the euro license plate is in the way.
Otto
Otto
The later pic's I enclosed are AFTER the lower plastic spoiler guard was taken out, in order to let the spoiler beam be "freed up", as per the first article you enclosed which was already read and followed. The problem is that after this initial repair, the smile was still crooked, and was then told that the only repair left was to replace the plastic mesh since the one in the car was missing its clips. After the mesh was replaced, the car still looked the same, even with the new part. Allegedly, the unevenness is due to the spoiler having been in the smashed up position for a long time, which then caused the permanent bend towards the passenger side. If you look at before/after pics, it almost seems the bend on the spoiler beam worsened than how it was before the actual repair attempt!
I have doubts that this is the best it could be, since the rest of the car is in very good shape. Any suggestions?
Hey Otto, If you haven't alreay done so, I'd highly recommend that you inspect the piece, yourself. The explanations you've received strike me as speculative at best. The fix is VERY straightforward and easily accomplished by someone with just a slight bit of mechanical ability.
If you don't feel comfortable tacking this yourself, I'd recommend that you find a different shop. Here's a pic of my 130K-mile C2 which has seen more than its fair share of bumps, scrapes and knocks. An hour, or so, with jackstands, screwdriver and pliers had her looking good as new.
![](https://rennlist.com/forums/members/joey-bagadonuts-albums-car-pics-picture3554-gman-2009-004a.jpg)
![](https://rennlist.com/forums/members/joey-bagadonuts-albums-car-pics-picture3553-gman-2009-002a.jpg)
the lower black plastic spoiler comes off with about 12 screws. Once off, take a pair of pliers and straighten out the metal lip the spoiler attaches to. 30 minute job and very easy.
I did these repairs, and I also fit a small block of hardwood into the lowest front gap, just to push the plastic down to the right level. I painted the block black so it is invisible, and now I have a straight smile.
You can fix this. Look how mine looked at one time
https://rennlist.com/forums/964-foru...ighlight=frown
