93 964--Erratic Oscilating Idle
Help! I have made 2 visits to a very well respected and knowledgable P mechanic but still have a problem. I thought I would get the boards input before going back for a 3rd visit.
Sometimes but not always, my idle oscillates betw 100 and 250 rpms . All the while, my oil pressure gauge seems to oscillates even more. Indeed, sometimes the tach is constant but the oil pressure still oscilates. On occasion , car will stall when I come to a quick stop. The idle stabilizer valve was cleaned. The O2 sensor was replaced. An electrical connection with the A/C system was fixed. Nevertheless, I still have the oscillating idle most of the time. Help! Thanks, Gary
If not LW flywheel, my next guesses would be:
1. An intermittent air leak in the intake system
2. Intermittent spark from a bad coil.
A idle speed with low oil pressure, the pressure could change dramatically with a very minor change in the speed, whci could explain why you're thinking the oil pressure is fluctuating with no change in speed.
Idle control microswitch??? I had a similar situation with my 94 964 and turned out to be a microswitch not closing the loop therefore ECU thought the throtle was still partially open and it would cause an erratic idle and even make it die.
