964 Forum 1989-1994
wheels fittment on 89 c4
Old 06-01-2010, 08:04 PM
kboustani
kboustani's Avatar
Default wheels fittment on 89 c4
will these wheels fit on my 89 c4.
2 - PORSCHE 996-362-124-02 10 SPOKE / 02-04 911 wheels 7J X 17 ET50 offset
2 - PORSCHE 996-362-128-02 10 SPOKE / 02-04 911 wheels 9J X 17 ET55 offset
Old 06-02-2010, 12:44 AM
misterbeverlyhills
misterbeverlyhills's Avatar
The rears yes for sure, the fronts I am not sure. Photos?
Old 06-02-2010, 02:18 AM
hamah
hamah's Avatar
All of the 7" wheels I've seen used or approved for use in the front of a 964 have an offset of ET55 so I would be careful there. If you don't already have the wheels and/or aren't totally committed to the style I'm going to be selling a set of the Porsche BBS Sport Classic 17s (7s and 9s) in perfect condition that came off my 91 C2 Cab so I know they will fit. Here is a pic if your not familiar with this wheel style (this is a replica but you will get the idea).
Oh...and you do know that if your going from 16 to 17 inch wheels you will need to replace the stock 6mm steering stop with a 10mm one? In addition you will need to do a small fix to a bracket in the wheel well that will rub if not dealt with. Here is a handy doc if you've not seen it.
Old 06-02-2010, 05:24 AM
Computamedic
Computamedic's Avatar
Both should be fine. An ET55 front wheel will only protrude a few mms more than a standard wheel and will give a little more clearance for the wheel on full steering lock.
The rears are fine. A 10J/ET47 fits OK so a 9J/ET55 will have plenty of clearance.
Regards
Dave
Old 06-06-2010, 12:05 AM
kboustani
kboustani's Avatar
i read somewhere,if you use 5mm spacers you wouldnt have to replace steering stops.anyone had experience with that?
Old 06-06-2010, 03:45 AM
Computamedic
The 10mm steering stops effectively reduce the turning circle of the car by reducing the angle to which the wheels can be turned. This helps the problem encountered with some 17" wheels by leaving some additional clearance when on full lock. 5mm spacers will achieve much the same result without restricting the steering lock. It all depends on the offset of the 17" wheels. The reply I wrote above mentioned ET55 front wheels but I notice that your original post states ET50 (did you change it or did I mis-read it?). An ET55 wheel with a 5mm spacer/shim is the same as an ET50 wheel without the spacer.
Regards
Dave
Old 06-06-2010, 01:32 PM
kboustani
kboustani's Avatar
i get it.i need to look for offeset of 50 for my front.
Old 06-10-2010, 12:59 PM
kboustani
kboustani's Avatar
is anyone runnibg this set up?trying to decide if i want these wheels.
Old 06-11-2010, 04:34 AM
maxterrier
maxterrier's Avatar
i've been using the cup II (993 wheels) in my 964 C4, 7 et 55 and 9 et 55 without problems; and et 50 is better in the front to prevent rubbing with 225 tyres.
Old 06-11-2010, 08:25 AM
jimq
Burgled
jimq's Avatar
I went to 17" without changing the stops and only get a tiny bit of rubbing from the tires on the inside at full lock. I havent ever read about the other rubbing spot. Guess I need to check that.
Old 06-27-2012, 10:06 PM
ahhprods
ahhprods's Avatar
Ahhh.. My exact question, except do these wheels fit on a 1996 993 carerra 2 cab?
Let me post in the right forum, sorry!
Old 06-28-2012, 01:16 PM
kboustani
kboustani's Avatar
exact wheels i have ahhprods.mine fit amazingly well with no problem,but its a 964 not 993.i would think they should fit fine on 993 since a lot pf 964 buy 993 whels and fit them on their cars.btw this wheels are awsome.
Old 06-28-2012, 02:13 PM
ahhprods
ahhprods's Avatar
yay! i found a set of 4 and am getting them for 700 plus shipping cost, supposed to be in mint condition. seems like a great deal
Old 06-29-2012, 12:02 PM
kboustani
kboustani's Avatar
get them.yoy will be pleased.they make the car more modern.
Quick Reply: wheels fittment on 89 c4
