16" D90 brake upgrade??????
Looks like 993 brakes, might work. Has anyone tried fitting a D90 wheel over a 993 front caliper. I found this link http://www.kurquhart.net/photos/Pors...rticle2005.pdf
16" can accommodate even 993RS/tt fronts radially, but axial clearance is rare in that size.
to use 993 front brakes it's easiest to use 993 uprights then everything just bolts up and you won't need special caliper adapters.
you would also want to use 993 rear calipers on your stock rear rotors and a 993m/c and booster.
