964 Forum 1989-1994
Engine Rebuild
Old May 25, 2010 | 01:20 PM
Greg964's Avatar
Greg964
Originally Posted by axl911
Just remove the compressor and the line. They just unbolt. Leave the compressor mount. You can probably also remove the front condenser. Again, they just unbolt. If you ever decide you want AC again, just bolt everything back in and re-charge it. Easy.
If you do this make sure you securely cap the refrigerant lines at the compressor(and condenser). A/C systems do not like to be contaminated with moisture, particles etc.
Old May 25, 2010 | 10:23 PM
92silver964's Avatar
92silver964
Originally Posted by TR6
I'm going to have to disagree on this one. I have the RS LWF and clutch and I also bought a brand new ISV (after several clean out attempts on the old one) and I have now been through three different Steve Wong chips. Result? My RS America still sometimes has a tendency to stall at lights or in traffic if I have the AC running. I'm not saying not to do the LWF and clutch mod. It really wakes up the throttle response and rev matching and it makes the car a whole lot more fun. But just be aware that it may come at a cost of having to manage the stalling tendencies. Everything is a trade off.
When I was asking my mechanic his opinion on the LWF, another 964 owner overheard and basically made the same comment you did. He said he finds the LWF to be great for racing but the rpm drop / stall issues while street driving to be undesirable. Thanks for your opinion.
Old May 25, 2010 | 10:29 PM
92silver964
Originally Posted by mr pg
I have a targa with A/C, and find if driving it in heavy rain, the only way I can keep the screen clear on the inside is to use the A/C. I want to reduce the weight a bit, but my A/C is staying.
I hear your good point, but since I try to avoid driving the car in the rain (not my DD) I'm hoping the loss of AC won't really affect me there. I'm sure you are absolutely correct that defrost without AC doesn't cut it. Thanks!
Old May 25, 2010 | 10:31 PM
92silver964
Thanks, Axl! Sounds good to me.
Old May 25, 2010 | 10:32 PM
92silver964
Roger that. Thanks, Greg.
Old May 26, 2010 | 02:48 AM
Jimjacqmx5's Avatar
Jimjacqmx5
I can recommend the Dougherty DC21 Cams. They work nice in a stock motor and give a noticeable increase in performance. For around $600 a set it's a great thing to do while it's in bits.
I got 225enginekw with the cams, a $60chip and a basic exhaust. (Primary bypass, 100 cell CAT.)
Old May 26, 2010 | 12:13 PM
TR6's Avatar
TR6
BTW, be careful of getting sucked into scope creep. The engine rebuild on my RS America started at an estimated $12K and ended up over $17K by the time we got through doing all the "while we're in there" and "this would be a great upgrade" stuff. But on the plus side, my engine is much more bullet proof now than when it left the factory in 1993.
Old May 26, 2010 | 11:22 PM
92silver964
I will check that out - very promising advice. Thanks!
Those sound like they could become familiar numbers! But I do appreciate your cautionary advice.
7 Porsche Models That Have Aged Like Fine Wine
Old May 26, 2010 | 11:45 PM
swftiii's Avatar
swftiii
Taylor is solid and had done a lot of the maintenance on my 993 when he was at ASG. I would gladly have him working on my 964, but he has moved to the new shop which is another 30 minutes or so farther away from me and Geoff at ASG is also a solid guy that I trust.
Your in good hands and if Taylor says it is time for the build it is truly time. He isn't one to push for something when it isn't needed.
-Skip
Old May 27, 2010 | 11:41 PM
92silver964
-Skip
Thanks, Skip. Very nice to hear praise for the guy I'm banking on. I appreciate you passing it along.
Old May 28, 2010 | 07:59 PM
misterbeverlyhills's Avatar
misterbeverlyhills
Geez, I am at 150,000 this weekend and the car pulls like a train, all original from the factory. Good luck, are you sure you need a complete rebuild?
Old May 28, 2010 | 10:56 PM
92silver964
Too late now. I go in a week from today to look at the stripped down engine (top end only so far). We'll discuss where to go from there. So, I'm in - I might as well enjoy it and not look back.
Old Jun 1, 2010 | 11:01 PM
92silver964
Help, I am being pulled into the vortex and I can't resist!
Seriously though, I am making a visit on Friday (3 days from now) to review the disassembled top end and confab with the mechanic about where to go from there. I think I have decided (unless he talks me down) to ditch the A/C. I am also leaning towards a cam upgrade (I did contact Dougherty and they recommended a regrind), so I need to follow through on that.
Any last minute comments on what to look for or ask about? I'll get some photos too. Your helpful thoughts are always appreciated! Thanks.
Old Jun 2, 2010 | 03:53 AM
1990-964's Avatar
1990-964
I find it interesting about the LWF and stalling. While I do know many have suffered from it, there does not seem to an iron clad reason for why some do it and some don't. I decided to have one installed by a respected local mechanic that gave me a guarantee that if it was not to my satisfaction and he could not get it right then he would return it to the DMF for free. Well I never had the stalling issue and have had it in the car now for over two years and well over 25,000 miles. It can stall once in a while with the A/C on when coming off the highway but otherwise causes no problems. The setup I have is the factory RS flywheel and matching disc and pressure plate. The funny thing to me is that when he installed the LWF no other mods were made to address the stalling. It just never became a problem. I also get almost none of the noise that others posters have talked about. Except for a little gear rattle when lightly lugging the engine, like rolling from a stop in second gear, it makes absolutely no perceptable noise whatsoever. With my experience I would not hesitate to encourage others to do the LWF.
Old Jun 2, 2010 | 09:45 AM
J richard's Avatar
J richard
The LWF is a real crapshoot. You will either have no problem or an ongoing not fun to drive (and problematIc for resale) car. The more mods done to the engine, open intake, cams, exhaust, and the more accessories regularly used; AC, lights etc...increase the probability you will have a real driveability problem. I see NO advantage to doing it for a street driven car, in fact I think it hurts low end throttle response. The real benifit is high rpm matching on the track. I have two, and one car has been switched back and forth because I thought I has a better solution, no so the street car is going back to DMF, the LWF stays in the full race car.
Some get lucky and only have slight problems but it's not worth the risk IMHO...
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
