My left electric window said goodbye (help please.)
Hi!
This weekend I repair the roof unit center control and I clean it, fixing it, but now my left electric window doesn't work.
Electricity goes to the switch, and it isn't the switch..
I will have to dissasemble the door panel....
¿What can it be?
Regards guys!
¿What can it be?
Regards guys!
I had a window motor on my 964 go bad. I pulled the power lead going to the motor and verified I had 12V going to the motor. It would switch polarity depending on which way the window switch was positioned. You don't need to pull the window mechanism apart to swap out the motor. Once you get the door panel off you can get to the window motor screws. I think there are three of them.
Door panel removal guide (by Marc Shaw)
https://rennlist.com/forums/showthre...ferrerid=19642
Let us know how it works out?!
