964 Forum 1989-1994
Chip
Old Apr 27, 2010 | 11:13 PM
cornerhans's Avatar
cornerhans
Default Chip
Does anyone know if the numbers should match between the chip (pictired left) and this other chip or what ever it is insided the same box?
Old Apr 28, 2010 | 12:40 AM
joey bagadonuts's Avatar
joey bagadonuts
Wow, I just posted this in another thread. ECU part # is on the cover: 261 xxx xxx. The chart, below, will tell you what chip is approrpriate for each ECU. Not sure what the other chip in the box is for:
File Type: jpg
File Type: jpg
Old Apr 28, 2010 | 09:18 AM
cornerhans's Avatar
cornerhans
J,
You are a gentleman.
Thank you
Old Apr 28, 2010 | 09:39 AM
joey bagadonuts
Old Apr 28, 2010 | 01:22 PM
christallon's Avatar
christallon
FYI.....That long chip installed in the ECU (Pictured above) is not the interchangeable chip. I'm not sure what that is for. The interchangeable "chip" is found under the plastic cover on the other half of the motherboard.
Old Apr 28, 2010 | 08:41 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Old Apr 29, 2010 | 11:31 AM
Lorenfb's Avatar
Lorenfb
"I'm not sure what that is for."
That's the knock control microprocessor (basically Motorola 68000 family).
