Primary / secondary muffler bypass?
Super Duper Moderator
If you are after a great noise, no drone and some performance I can highly recommend a maxspeed primary muffler bypass, 100 cell cat pipe and exhaust tip. Looks great and sounds great with no drone. www.maxspeed-motorsports.com
Combine this with an accel racing chip from Steve (from UK on ebay) and I got a dyno proven 204kw on a certified porsche centre dyno. That's a 20kw increase for minimal outlay.
It is worth mentioning that biggest advantage of removing primary muffler rather than secondary (G-pipe) is that the primary muffler hangs at the very rear of your car so removing the weight from there is a good thing.
Hope that helps.
Hope that helps.
In short, yes, the accellracing chips work really well in my experience.
Steve is also a really nice guy to deal with.
I have sent you a PM with some further info.
Cheers
Cheers
This is the first time I've seen this part, and I wonder why all 964's don't have this instead of their hot air intakes
http://www.maxspeed-motorsports.com/964aip.html
In this example, the Maxspeed air intake points straight up (vs. the horizontal opening of the factory part)...I hope there are drainage holes already pre-drilled at the bottom to let water out?
I imagine you would still get a better gain from a proper pod filter installation, ie, installed so filter is located just under spoiler such as the EVOMS intake kit or by just cutting the back off your factory airbox, although I always suspected this would suck too much hot air.
Obviously the pod kits with no elbow to move filter close to cold air are a waste of time a they just suck hot air.
So are the cup cars supposed to keep out of the rain? I don't see the logic otherwise. What about when a cup car gets washed ... that snorkel would fill with water, or worse. Perhaps it has drainage holes? Do they make a whistling sound, if so?
I can't speak for every owner, but generally race cars don't get washed....most people with really expensive/rare cars don't bathe their cars in water
I imagine you would still get a better gain from a proper pod filter installation, ie, installed so filter is located just under spoiler such as the EVOMS intake kit or by just cutting the back off your factory airbox, although I always suspected this would suck too much hot air.....
Marc
