Rear bilstein dust boot and bump stop
Registered User
Does anyone have a spare rear bilstein bumpstop and dust cover that they dont need??? I have contacted bilstein and they cant locate one (wtf??) so if anyone has these they dont need i would like to buy from you, i only need for one shock.
there certainly is a lot of mis-information out there on this suspension setup. I've just ordered bilstein hd's and H&R springs for my 1990 C2. Shox.com could not tell me if they required external bump stops so I called bilstein (California) and was told that both the front and rear hd's have bumpstops built in. Funny thing is, the guy was't too convincing - he sounded as if he really didn't know. Strange that this information is readily available.
I cannot find boots (dust covers) for the rear shocks anywhere. The guy at bilstein said they aren't needed.
The stuff hasn't been delivered yet. Shox.com at first said the stuff would ship next day, now I'm told the left front strut is backordered at bilstein and will not ship until next week. Disappointing.
I wish someone out there was more definitve about these suspension components.
When I installed mine I ordered the stock Porsche dust boot and bumpstops from Sunset Porsche and installed them on the struts. I cut the bumpstop to make up for lower suspension settings I am using (european RS spec).
Spokes (06-14-2024)
Got a smokin' deal from Neil at Sonnen Porsche on all these installation parts, the rear bump stop is $13.03 and the rear shock protection tube is $6.72:
Front Shock Mounting Hardware
900-067-310-09 (4ea) Cheese Head screw M12 x 1.25 x 90 (camber adjustment)
999-025-212-09 (4ea) Washer 12.5 x 24 x 3
999-084-623-09 (4ea) Locking Nut M12 x 1.25
900-076-025-02 (8ea) Front Shock Upper Mount Lock Nut
900-025-007-02 (8ea) Washer
964-341-511-80 (2ea) Gasket
Plastic pieces for ABS
928-612-409-00 (2ea) Abs Ground Wire Clip
928-612-531-00 (1ea) Abs Interference Shield Connector (L)
928-612-531-01 (1ea) Abs Interference Shield Connector (R)
999-591-931-40 (2ea) Clip
Rear Shock Mounting Hardware
900-082-102-08 (2ea) Bolt Hex Head M14 x 1.5 x 100
999-025-149-02 (2ea) Washer
999 084 622 02 (6ea) Locking Flange Nut M8 (up to 1990)
999-025-125-09 (6ea) Washer 8.4 x 17 x 3.1
928-333-518-10 (2ea) additional spring
964-333-502-01 (2ea) protective tube
