Manteinance for a track day 964
Hi:
I am using my 964 exclusively for track days, I just brought it today to to the garage to make some work on filters, brake pad change...
I am thinking on wether there is some additional manteinance that is exclusive to track use, I should be doing to my car on top of very frequent change of fluids, filters and others which I already do.
Thanks for your advise...
Sergi
Sergi
Hi:
Sergi
Sergi
Good list, Dave.
If this is a track-only car, I would also recommend that you use racing pads, remove the dust shields (plate on the rotor back side), remove the proportioning valve and replace the fluid with Castrol SRF. Also check the wheel bearings, CV lube and alignment/corner balance. Remove any loose or unnecessary items.
How many miles on this car? Dave's checklist should cover most things and I'm sure you've inspected every brake line and seal but knowing a little more might stir up additional thoughts.
A couple other suspension items you may want to check are the age/condition of shocks. If they're older, they may require maintenance or replacement. Also, the anti-roll bar drop links should be inspected along with all bushings and movement.
Install tow bolts on the front and rear. Apply 3M headlight and fog light protective film. Double-check that all lights (especially brake lights) work. Confirm that LSD is operating within spec.
Have fun and be safe!
Thanks Dave and Joey for your kind advise:
We are going to lift the car "nut and bolt" and check on all the suspension, brakes, LSD...
Car is 100.0000 miles but 2000 mile ago engine was opened, seals replaced RS clutch installed, added LFW ( 8000 € invoice).... Suspension is now RED H&R dampers and springs, I am using racing pads, Castrol SRF... the whole thing is pretty well speced to have fun on track use, except brakes where I am still investigating what to do to avoid early overheating... so I now need to make sure it stays in place so your recommendations are all great. thanks
By the way Joey, do you know where to purchase Tow bolts which suit Porsche bumpers?
Sergi
Sergi
In the US, Paragon seems to have a good deal at $13.95
http://www.paragon-products.com/prod...721.151.00.htm
This issue is hard to diagnos without knowing how you use your brakes prior to failure. In general, if you avoid engaging the ABS and utilize new race pads, SRF and improved cooling (removed dust shields), then I would not expect the brakes to overheat. Continued, hard braking will overheat the tires before boiling fluid or glazing pads, so it's important to adjust your braking point as grip levels change.
The trap many track drivers fall into is to maintain the same braking points throughout a session and brake harder when tire grip fades. The right answer is to brake sooner.
Also, you might want to confirm that you're using the correct air pressure for your tires. Overheated tires are often the result of cold pressures which are set too low. I use a probe-type pyrometer to determine the right pressure.
Funny I didn't realize how cheap they were. I only had two laying around, but going to Laguna last week........with the gravel traps everywhere..........I wanted front and rear for both cars. So the having them both on the yellow car won out.
Sergi,
As far as brakes - there were a couple of posts just recently in the Racing and in the 964 forum that I posted to with my issues of past and what I've done to address (this is what worked for me and I seem to be pushing the brakes pretty hard).
As others have said:
1. Castrol SRF (fresh)
2. Stainless brake lines
3. I use Porsche solid rotors (not sure if cross drilled will make a cooling difference, but something to look at)
4. Good track pads - I've tried PFC 97s and had issues, switched to Pagid Yellow RS29s and have been happy since with no soft pedal issues
I'm going to use some rotor paint to see temps next time I hit the track, but that won't be for a few months.
Get out there and anjoy the car...
-Skip
-Skip
Hi Sergi
don't think it's been mentioned yet, but it's worth checking the condition of the engine carrier and making sure there are no early signs of cracks developing. There have been a few threads from unlucky guys who suffered catastrophic failure of the carrier, especially under the larger stresses of track driving. I think this failure is more likely if the engine mounts have failed or been replaced with performance items. There are options to re-inforce the carrier. Search of threads here should tell you all you need to know.
Cheers
Greg
Cheers
Greg
In terms of PITA factor, I'd say it's a 5 (less if you completely drop the motor).
Assuming you've got it lowered on a jack, the carrier, itself, is not that hard. It's the engine tin at the very back which offers some challenges. There are some tiny, hard-to-reach bolts holding it in place and then it needs to be "coaxed out" ever so gently so that you can slide the bracket out. Having a friend help (eyes on top) makes it a lot easier, as well.
Well worth the effort, though.
