964 Forum 1989-1994
Project Shrek: electric riddle
Old 03-01-2010, 02:27 PM
dutchcrunch
dutchcrunch's Avatar
Default fuel
we do not know how he is wiring it. he said directly, maybe he went straight to the pump. there is a fuel pump fuse # 34 according to enthusiasts companion. i would check that if you wired directly.
dutchcrunch is offline
Old 03-01-2010, 02:28 PM
darth
darth's Avatar
Dear Indycam
"If he is getting the motor to run with a jumped dme relay , he must be doing the jumper correctly ?" I didn't say he was jumping it incorrectly. The fact that the "fuel pump kicks in for half a second then stops" and not being intimate with the circuitry, tells me it must be getting a signal to turn off which I suspect is the 3rd lead. If a 2 wire jumper is used this suspect signal is eliminated. When I drained my tank I simply used a 2 lead jumper to keep the pump on continuously.
Bill
darth is offline
Old 03-01-2010, 02:42 PM
Indycam
Indycam's Avatar
Eh ?
Indycam is offline
Old 03-01-2010, 04:05 PM
rattlsnak
rattlsnak's Avatar
to confirm, is this on an 89 model? the pre 91 cars have a seperate alarm and lock module, whereas the 91 + cars have the lock and alarm modules combined into one under the pass seat.
Anyway,, on the DME relay..
pin 3 = batt voltage at all times
pin 6 = ground
pin 1 = batt voltage WHEN CRANKING. this feed is from the alarm module.
pin 5 = batt voltage when cranking. this feeds fuse 27 tip if equipped.
pin 8 = ground supplied by ECU, when it receives crank signal, etc.
pin 7 = 12 v output to fuel pump
check the above in that order and post your findings.
rattlsnak is offline
Old 03-01-2010, 04:15 PM
GeorgeK
GeorgeK's Avatar
Good info and interesting questions. I will pass them along to my mechanic. I will develop as I get info.
Thank you all so far.
GeorgeK is offline
Old 03-02-2010, 04:20 AM
GeorgeK
GeorgeK's Avatar
Update:
We have determined that the fuel pump draws far too much current. Is there a surcharge protection in the standard DME/Fuel pump circuitry?
GeorgeK is offline
Old 03-02-2010, 11:56 AM
Indycam
Indycam's Avatar
Does it blow the fuse ?
You have not said anything about any blown fuses so its hard to see how its pulling to many amps .
Indycam is offline
Old 03-02-2010, 12:12 PM
dutchcrunch
Default fuel pump
the fuse for pump is a 15 amp.
Old 03-02-2010, 12:20 PM
GeorgeK
GeorgeK's Avatar
No Blown fuse. We suspect there is a surcharge protection in the relay or DME (?). It is pulling too many amps that is a certainty.
GeorgeK is offline
Old 03-02-2010, 12:34 PM
Indycam
Indycam's Avatar
It pulls to many amps but does not blow a fuse ?
You are thinking maybe something else is watching the amps and shutting off the flow before the fuse blows ?
Indycam is offline
Old 03-02-2010, 12:37 PM
GeorgeK
GeorgeK's Avatar
Yes. Is there a surge/overload protection in the relay or is it related to a DME function?
GeorgeK is offline
Old 03-02-2010, 12:48 PM
Indycam
Indycam's Avatar
I have had the cover off of the dme relay and have not seen anything that would jump out at me as a amp check / control . But I can't say I looked for that . The idea that it might , makes we want to test .
I don't know how the dme itself would "see" the amps going to the fuel pump .
If there was a shunt in the wire to the pump and the dme watched the amps via the shunt ...
But I have never seen a shunt in a 964 .
Indycam is offline
Old 03-02-2010, 12:52 PM
rattlsnak
rattlsnak's Avatar
No, neither has any kind of surge protection... if it draws too many amps, it pops the fuse. period. did you check the pin outs as i posted earlier? It sounds like your guy is chasing his tail. if you give us the readouts from the pin outs, we can further help you.
Old 03-02-2010, 01:30 PM
GeorgeK
GeorgeK's Avatar
I doubt he is chasing his tail, because he is not paid for that work. And he very much knows these cars.
Anyway, I will not access the car until saturday, so I have phone talks with hin only now. I pass on the info as I get it, both ways.
I'll update as it comes.
GeorgeK is offline
Old 03-02-2010, 01:39 PM
Indycam
Indycam's Avatar
When you jumped the dme relay and the pump ran and the engine kept running and no fuse blew .
That makes me think that the pump was not pulling more amps than the fuse could handle .
I wish I was there .
Indycam is offline
Quick Reply: Project Shrek: electric riddle
