New Koni Struts at Tirerack. Which to order for 1989 C4?
Tirerack has the new Koni's, complete assemblies. I had my original shocks replaced with Bilstein HD which are way too stiff, I want to try the Koni's. Does anybody know which of these part numbers fit the REAR of my 1989 C4?
I want to avoid the cartridge inserts since I do not have the original shocks anyhow.
Thank you!
Thank you!
Thank you everybody for your responses. I realize already that KONI stopped making the rears for 1989 C4's a long time ago. However, it looks like they may be making them again, Tirerack is listing them now and available in a few weeks time. The question is which to order? One model is for cars with Boge shocks, the other for Boge or Koni. I am not sure what my car had, but it has Bilstein HD now, complete assembly up front and rear, not some kind of cartridge insert.
Thanks again.
Thanks again.
Have you considered Factory replacements? If the Bilsteins were too stiff, I'm not Koni's will be much better. The stock parts, however, definitely provide a more compliant ride.
$0.02
$0.02
Thanks again.
Thanks again.
Tirerack is listing struts for the front .
If you are asking about koni shocks for the rear of your 89 , you can't get them from tirerack , imho . I took the part number from tirerack and crossed it at the koni site , the part number that tirerack has for the rear shock is a front strut .
If you are asking about the front struts for your 89
8641 1365Sport
http://www.paragon-products.com/prod...1541lsport.htm
http://www.paragon-products.com/prod...1541rsport.htm
http://www.paragon-products.com/product_p/2100-4111.htm
91-94
