964 Forum 1989-1994
Varioram Project Started
Old 02-08-2010, 12:05 PM
axl911
axl911's Avatar
Gus,
If you want stand-alone vram activation, I would go with two RPM switches which can be had for $100 each from summitracing. This will also allow you fine tuning.
You can try to look for a 993 AC hose which would run along the back of the car to fix your AC hose problem.
What are your expectation when this project is completed? More hp or simply more torque in the low RPM range?
Old 02-12-2010, 04:17 AM
JM993
JM993's Avatar
Originally Posted by mnmasotto
Gus,
I am I hearing correct? You are using the stock 964 Motronic ECU and wiring harness with the Vram induction system? Please elaborate. I have a 1993 964 ECU and induction system on my 1995 long block. I no it is far from optimal. I want to convert over to a Vram induction system but do not want to fool around with a new wiring harness and having to find a Euro 993 ECU.
Thanks for you time, Mark
Note that you can use a later US 95 993 OBD-1 ECU with the with a Euro chip to run the VRAM. Check out my sig for a detailed discussion of ECUs.
Gus, re your AC hoses: I updated to the later 96-up hoses (about $300 used), but I've also seen someone simply reroute a set of 95 993 hoses (they are virtually all rubber) the same way as the later hoses. Not sure if 964 hoses are different (at a glance the look similar) than the 95 993 hoses.
Cheers,
Joe
Old 02-12-2010, 04:55 AM
ACSGP
ACSGP's Avatar
I would have thought you could get both. Doesn't a stock 993 with varioram already come in at 300 bhp?
Old 02-12-2010, 05:47 AM
Megatron-UK
Megatron-UK's Avatar
I thought it was only a few ponies more than the 964? 275bhp or thereabouts?
Old 02-12-2010, 07:59 AM
mr pg
mr pg's Avatar
285BHP for the varioram, 272 without.
Old 02-12-2010, 01:07 PM
Gus
Gus's Avatar
Joe - Problem with the 964 AC hose is the aluminum tubing right as it comes into the engine bay area. It bends back to the front and then across to just short of the intake area before it bends and heads to the rear across the intake manifold. If you could straighten the aluminum tubing you could make it work - I think need to get the 993 - 96 hose - The line needs to come to the rear as it comes into the engine bay - run along the left side of the engine (by the rear fuse box) then bend to the right and go by the distributors and over the fan to the compressor at the rear of the engine - You just can't make the 964 lines do that. The other mod that would really be nice would be to change to the 993 fuel lines, rails and regulator as this would clean up the multi-fuel line mess in the middle area under the manifold hose.
Oh! have traced the leak up to the check valve so far - hope that is it -
Old 02-12-2010, 03:40 PM
BlueHeeler
BlueHeeler's Avatar
Also consider the 964 exhaust system is far from ideal. The 993 is a much better design IMHO.
Old 02-17-2010, 10:01 PM
ACSGP
ACSGP's Avatar
So, if I get it right, you have to change the 964 AC hose to fit the varioram, and substitute it with a 993 version. Is this just a bolt on, or do you need to adapt the 993 lines?
Old 02-17-2010, 10:25 PM
Gus
Gus's Avatar
ACSGP - I am hoping that it is just a matter of getting the hose and putting it on - hoping that both ends mate up without any issues. But right now that i not a major problem, as the last thing I need right now is a functional AC. Other issues that you will run into are the cruise control - need to obtain a 993 cruise control mount - modify mount to fit around fuel lines or - best move is to get 993 fuel lines and regulator as it is a simpler system and opens up room under the Varioram for the cruse control -
Quick Reply: Varioram Project Started
