Heater blower ticking
My drivers side heater blower makes a ticking sound that corresponds to blower speed. I'm thinking there is something in there interfering with the blower in some way. Anyone encounter this? Do I really need to pull the fuel tank to get in there?
Also, I've recently blown a fuse on the blower circuit -- I'm fairly sure these would seem to be related...
Thanks,
Jeff
Thanks,
Jeff
You can get to the blower without pulling the fuel tank. You will have to remove the expansion tank on top of the fuel tank, remove the filler hose between the fuel tank and the filler pipe and loosen the fuse panel and pull it out of the way . Remove six screws and one bolt and pull out the firewall. Take the clips off of the cover over the fan and now the fun begins.
See this thread for the details:
https://rennlist.com/forums/964-foru...ght=blower+fan
You can buy a new drivers side blower from partsgeek.com for $635 and that's the best price I have found. I'm working on overhauling mine. Will see how it turns out.
The left hand blower in my car would chirp after 30 minutes of operation. Rather than spend the $550 to replace it right away, I was told by my local Bosch starter motor rebuilder to spray some aerosol anti-seize into the bearings.
I sprayed both motors over the winter and I'm happy to report that the chirping has been eradicated. I'll report on it again at the end of the season.
