964 OBD 1 convert to OBD 2
Due to test requlation, my 964 needs to convert from OBD 1 to OBD 2...Dose anyone think it will have problem that signal can not read out from the computer? Is 964 designed to be analog signal? Any other solution could convert it through software?
where would this be required?
typically the test criteria is by the year of manufacture.
As bill said you would have to repalce the entire motor - harness (s) exhaust system, etc. and depending on model there could be a 100 other things to modify or replace along the way (if you have a C4 or a Tiptronic for instance it would be more complicated.
I am located in Taiwan. The test center ask for OBD 2 connector. I am wondering if there is a offself solution someone make a cable which can convert from 964 round connector to OBD 2...
This should do it:
http://www.sensolutions.com/products...adapter-cable/
They have an office in Canada and somewhere in Asia.
Technical Guru
Electrically the 964 onboard diagnostics is the same as OBD2 (ISO 9141-2:1994) but the protocol used to communicate between the ECU and the tester is not OBD2. So simply replacing the cable/connector won't work. Unfortunately there is no easy or inexpensive way to do this.
I find it strange that they would even ask you to do this. Why would they need to plug into the cars fault diagnostics for a road worthy test? What would they do for even earlier cars with no plug at all?
I bought the cable from Sensolutions in Canada and plugged an OBD2 lead (16 pins) in, now I am
looking for the right software for the Bosch 2.1 Motronic. Any suggestions ?
p.s. I am looking at a carbon strutbrace for my 964 C2 are there any findings of members ?
Burgled
Dear all:
I found out that Durametric kit got this cable inside which I will borrow it from my friend. Taiwan's test requirement is the most demanding in the world and they do not want to see older car pass to get the plate...
