Brake booster pump troubles... again.
I'm on my third pump, granted the other two were used units. And now my hard line is leaking again.. I just replaced this line when I replaced the pump six months or so ago. I replace both relays last time as well. The line is leaking were it connects to the pump with the coter pin. Any thoughts on why I'm having so mant issues with this thing?? I'm hoping the pump is ok, my last repair bill was pretty steep when you factor in labor and all the parts I had to buy.
Digging through my old parts from the last repair I found the relays still in the boxes, they looked new. I'm thinking they didn't replace them when they did the repair. which may be the reason my pump did not shut off and caused another pump to melt. Will speak with them in the morning! And keep you posted. Now to try and track down another hose
