Time to Replace Carpet
The interior of the car is more important to me than the exterior. I guess it makes sense as that's where I spend most of my time with the car.
Anyway, it's time to replace the carpet in my C4. I've done a lot of searching here and the information I have found combined with experience I have had with earlier cars should enable me to blither my way through with the installation. But I have a few questions that I wasn't able to find answers to with the searches:
(1) I t seems that the RS kit from Appbiz.com is the popular choice. Is the best choice Perlon, Plush or Silverknit?
(2) What is the opinion of Dynamat? I have used it in 356's and long-hoods and have been very pleased with it.
(3) Everyone mentions that the factory glue is a bear. Someone mentioned that "Goof Off" works well - any opinion of that or other magic potions?
(4) I often wet the new carpet prior to installation in the older cars which makes it more pliable and easier to stetch. Has anyone done that with the Appbiz product?
Thanks for your help!
Cheers,
JohnA
Cheers,
JohnA
Perlon is very thin. Plush is similar to OEM carpet but a bit thinner. Silverknit is like OEM from what I understand. RS faithful use the thin Perlon, RS wannabe uses Plush, stickler for OEM uses Silverknit.
There are other choices, but if you want to use Dynamat, get the Extreme. Don't get regular, it stinks like tar on a hot day.
(3) Everyone mentions that the factory glue is a bear. Someone mentioned that "Goof Off" works well - any opinion of that or other magic potions? .
It is a bear period. No way around it. Be prepared to curse and kill about 1M brain cell from the fumes. I tried Goof Off but in the end, I used WD-40. I think there was another member who used a steam to just lift the carpet off and have the sound padding left in place.
The Plush is actually VERY stretchy. The secret to a good install is a good backing material or layer under the carpet. Otherwise there will be lump, bumps, wrinkles, etc.
Here is an excellent writeup by one of the member on PP & Rennlist.
http://forums.pelicanparts.com/porsc...-87-911-a.html
Cheers,
JohnA
Cheers,
JohnA
If you want any other factory color you will either have to buy bulk and cut and bind the carpet yourself or buy from a European vendor.
One source would be Lakewell
