964 Forum 1989-1994
2 quick questions about 964s and one specific one I'm looking at
Old 11-15-2009, 09:52 AM
Optical TDI
Optical TDI's Avatar
Default 2 quick questions about 964s and one specific one I'm looking at
I'm looking at a 1991 964 for sale here.
What model year did the head gaskets come into play?
How long does it take to adjust the valves for a DIY guy?
How much does it cost to have a shop adjust the valves?
This looks nice...any thoughts?
Category: 911/993/996 Ad Number: 9094
Price: 17500.00 Date Posted: 08/01/2009
Features
Year: 1991 Make: Porsche Model: 964 C2
Miles: 92000 Engine: Fuel Inj. Stereo: AM-FM/CD
Body Style: Coupe Transmission: Manual - 5 speed
Color: Amazon Green Drivetrain: 2 Wheel Drive
Options (denoted by check marks)
Power Steering Air Conditioning Rear Defroster
Power Brakes Sunroof Leather Seats
Air Bags Cruise Control Foglamps
Antilock Brakes Power Windows Alarm System
Traction Control Power Locks Intermittent Wipers
Description
Born on date: July 18, 1990, 234th 964 coupe vehicle off the line.
VIN: WPOAB2968MS410234
Engine: M64.01-62M, 3.6L air-cooled, No. 62M01394
Transmission: G50/03, 5-speed manual
Color: Amazon Green Metallic (special order)
Interior: Black and Beige, partial leather
Corner balanced and setup for track if desired
Option codes:
C02 - Catalytic
158 - Blaupunkt "Monterey" Sound system (upgraded to Alpine)
286 - High Intensity Washer
288 - Headlight washers
425 - Rear wiper
437 - Comfort seat
454 - Cruise control
494 - Rear speaker/Blaupunkt amplifier
650 - Sun roof
Mods:
I have performed the following modifications. Please note that I have retained all original parts for easy restoration to original conditions. All original parts will be transmitted to new owner.
• H&R Sport Springs (Stage 2 PN# 29813),
• Bilstein HD Gas Shocks (F4-B46-1735-H0) and struts (F4-V36-0385-HO).
• TRG Euro RS 3-way 18mm rear and 5-way 23mm front adjustable stablizer bars
• TRG "Cup" front strut brace
• Dansk Stainless-steel "Cup" primary muffler by-pass
• Mille Miglia Carrera Cup 2 wheels
• Bridgestone Potenza RE730 tires, 205/50ZR17 fronts and 255/40ZR17 on the rear.
• Miscellaneous:
-LUK flywheel upgrade
-Distributer ozone vent upgrade
-Sensitrac arm rest/drinkholder
-Alpine TDM-7534 head/CHM-S620 CD Changer
-Infinity Kappa 4x6 rears
-MB Quartz front separates
Bonuses: Extra Cyntex chip, 'Carrera Cup-modded" airbox and original Design 90 wheels mounted with Yokohoma tires with good tread life left are all included.
Old 11-15-2009, 10:02 AM
jim_l
jim_l's Avatar
reff jasons post related to the head gasket.
it took me maybe 6 hrs work over 2 day the first time adj the
valves. not sure what a shop would charge my guess would be $800.00.
best of luck to you.
"The 964 was gasket-less up until engine serial number: 62 M06836 for those with manual transmissions and 62 M52757 for those with tiptronics. If the work was done under warranty than the machine shop should have marked a -10 or -20 (the amount of inner surface that was removed) at the top of the cylinder head on the intake flange. Unfortunately you'll need to remove one side of the intake manifold to see that marking.
The C2 was delivered with the LUK flywheel in late 1992, from 1991 up until that time it came with the modified Freudenberg and before that with the original Freudenberg. The C4 was never delivered with a LUK flywheel but Porsche did switch to the modified Freudenberg in 1991. The ventilation for the ignition distributor was started on the production date August 13, 1993 with engine serial number 62 R00592 (5-speed) and 62 R50520 (tip).
Quick Reply: 2 quick questions about 964s and one specific one I'm looking at
