How to replace the rear engine compartment cable?
Greetings;
Firstly, thanks to all who have assisted me in ideas and suggestions for specific repairs on my 964. I have another issue to solve this weekend and I need help as I do not know where to start.
When I pull on the rear engine release cable (inside the drivers doors frame) nothing happens. I hear the release of a latch or something but the engine compartment will not open. If I reach around and pull on it when the cable is fully extended, the engine compartment releases. Is the cable worn, or does it need adjusting to work properly? I ordered a new cable (with handle) today but need DIY instructions to proceed when it comes.
Please don't hold back your suggestions...
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Greetings;
Please don't hold back your suggestions...![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
If you ever worked with the brakes on a bicycle, it is all the same in terms of the mechanics of it..
"Wachuko" I tried to adjust the cable (loosing the secured end and pulling on the cable with a pliers) but it never made a difference. When I get home tonight from work (9pm) I'll look at the latch mechanism again and re-evaluate the adjustment per your post.
Thanks always.
Thanks always.
That was mentioned by another friend elsewhere, so I changed out the rear hood shocks but it did not make a difference, so I'm back to the cable replacement or adjustment as mentioned earlier by "Wachuko."
Seeing as you have the new cable you might as well put that in. Just disconnect it at the latch and pull it out from the handle end. Then just thread the new one in from the handle. You can't go wrong as the tube containing the cable runs right from the door to the engine bay.
I'd say you need to do some lubing of the latch once you have attached the new cable. It's a strange mechanism in that it is spring loaded such that if the cable snaps (mine did at the handle), the lid should spring open (as a failsafe mechanism). However, I should say that this changed with the later cars when an emergency release cable and redesigned latch was fitted.
As boxsey says
from raamerica.net - Rear deck lid release cable failure
http://www.rsamerica.net/articles/te...id_article.htm
"boxsey911" thanks for the explanation and being so simple I'll be doing it tonight after work. Last night I re-attempted to adjust the cable once again but I got no more tension by pulling on the end to the latch and the engine compartment would not release by the cable. ![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
"911Jetta" thanks for the link indicating the emergency release cable. I never knew that existed and it's good to know for future reference, or to assist others.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
So hopefully I'll be posting that it's completed and works well. Thanks again guys.
When I put my new cable on, I recall having to hold the catch under tension against its spring before tightening the screw that holds the cable. Sorry that sounds a bit vague but it was nearly 3 years ago that I had to do it. Hope it might help you though.
