964 Forum 1989-1994
MY90 cylinder seals?
Old Nov 5, 2009 | 11:05 AM
964polar's Avatar
964polar
Default MY90 cylinder seals?
I am looking at a late MY90 964 C4 cabrio.
I gave away Adrians book with my previous car.
With VIN WP0ZZZ96ZLS421481, does this car have the cylinder seals or not?
Thanks in advance
Old Nov 5, 2009 | 11:38 AM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
The change was done mid MY 91. Most '91 models have the change as it occurred in the early part of production. If you don't have this info already, here it is again:
62 M 06836, M64.01 for manual transmission
62 M 52757, M64.02 for Tiptronic transmissions
Any car with a serial numbers that precludes or matches the serial numbers above will not have the cylinder head gaskets installed. You need to look under the car and check these numbers...
Old Nov 5, 2009 | 02:08 PM
jimq's Avatar
jimq
Burgled
Jaime I have looked for the numbers on my engine. Where exactly are they ?
Old Nov 5, 2009 | 03:37 PM
Computamedic's Avatar
Computamedic
To the right and below the alternator fan, as per the diagram.
Regards
Dave
File Type: jpg
Old Nov 5, 2009 | 05:16 PM
christallon's Avatar
christallon
If your build date was 11/90 or later you likely have the updated head configuration with seals. I have a July 90 build date for my 91 C2 and it does not have the update.
Old Nov 5, 2009 | 05:27 PM
jimq's Avatar
jimq
Burgled
mine is 9/90 but a TIP. I will take a look tomorrow not that I plan of doing anything about it anyways
Old Nov 6, 2009 | 12:54 AM
christallon
Many of the early cars never leaked anyway. It's become a bit of an urban myth in my opinion, but having an early car may sway my opinion a little
Old Nov 6, 2009 | 11:27 AM
964polar's Avatar
964polar
Thanks all of you, quick response as always
