Wondering if anyone knows how good the quality the andial med grade lightened flywheel kit is?the price of it is very reasonable!Has anyone hear used any of there products?
They take a standard LWF and bolt on a machined weight ring to the flywheel. Works quite well. I had it balanced before installation (after discussing it with Andial, it really wasn't clear that they balanced it).
I thought they took an 89 weight flywheel and added weight .
From my discussion with the guy , it seemed he thought an 89 weight flywheel would cause the motor to stall . I asked him if he knew that people had done good work on the dme chip to keep motors running lighter than 89 flywheels from stalling , he said he had no knowledge of them and that he did not think I was correct .
You should investigate what I had done on a race car (not Porsche) approx 15 years ago.
We had a small 1.7 liter engine that delivered its max power around 7000 rpm. The IDLE was really poor, almost impossible to maintain it under 1300 rpm (aggressive cams and carburetors).
I had added an electric clutch with an approx. 10lbs flywheel bolted where a fan used to be.
Every time the engine reached 2000 rpm the clutch de-clutched, which avoided the additional weight to affect the engine's velocity.
