964 Forum 1989-1994
Requesting wheel spacer advise.
Old Oct 5, 2009 | 06:18 PM
airfan's Avatar
airfan
Default Requesting wheel spacer advise.
I have CUP 1 replica wheels on my car.
Front wheels are 7,5x17 ET 52 with 205/50 tires.
Rear wheels are 9,0x17 ET 47 with 255/40 tires.
What size wheel spacers would you recommend, if any, when trying to improve handling?
Thanks all.
Old Oct 6, 2009 | 02:28 AM
joey bagadonuts's Avatar
joey bagadonuts
I run the same wheels on my race car. No spacers needed. They would just add weight without any performance gain.
Old Oct 6, 2009 | 09:16 AM
boxsey911's Avatar
boxsey911
Agreed that the offsets on those work really well. It won't be those affecting the handling.....if you have a problem with it, it's likely to be geometry/suspension related or tyre pressures/type.
Old Oct 6, 2009 | 09:12 PM
amr89c4's Avatar
amr89c4
That particular set up should not require spacers.
If you should decide to go to 225/45s on the front, you may need 5mm for clearance. I did. Or you can go with the thicker (10mm as I recall) tie rod stops.
