what makes oil pressure not be consistent?
I have a 964 that when you start it up and have it run the oil pressure jumps around from 2-4 bar which makes the idle jump around. Or is it the idle making the oil pressure jump around.... I dont know.
Engine sounds fine, seems fine. Smoked a little but nothing out of the ordinary.
Im just woundering why it is jumping around and not idle smoothly???
Nb. I tried replacing it with new aftermarket senders at first. These were disasters. Still jumped about or didn't work at all. So go for an OE one straight away if you decide to change it.
p.s. I think your pressure gauge and idle both jumping around are not related to each other and you have two minor problems to attend to.
