A/C compressor relay?
I started to do some preparations for my A/C system install! Can anyone point me where is A/C compressor relay positioned?
I saw in engine compartment that one relay is missing and on the box cover it`s written A/C 7.5A fuse (I have that one). What relay I am missing there ( far right spot is empty)?
IHI KING!
Alexx,
Do you have access to the factory manual or Bentley Technical data book? Both have the listing of all electrical parts and their physical locations within the car. I'm at work right now and my books are at home. If someone doesn't respond before I get home, I'll look it up for you.
http://www.bentleypublishers.com/isb...929/index.html
No affiliations.
No affiliations.
IHI KING!
Alexx,
I've responded to your PM but thought I should share the answer for everyone else.
Alexx,
Yes, I can confirm the green relay is the AC relay. I just checked my cabrio and it has the same relay. PET lists the relay as "double relay" but my Bentley specs book and Pelican Parts list it as the AC compressor relay.
AC relay
Original part number = 964-615-215-00
Superseded part number = 999-657-018-90
The third fuse is also associated with the AC compressor. Its a 7.5 amp fuse.
I hope this helps.
Originally Posted by Alexx
... I believe that he is positioned in engine compartment and it is small green relay! Can you confirm me that? Check this pictures:
![](http://www.villagephotos.com/utils/image.aspx?u=2008-9\1322043\W01331645998OES.JPG)
![](http://www.villagephotos.com/utils/image.aspx?u=2008-9\1322043\dcp_3258_800x600.jpg)
Alexx,
AC relay
I hope this helps.
