Ok, I think it is the relay but check me please
I moved my car Wednesday in the driveway and no issues.
I get in the car this morning and the car will not start. Turns over and over but no start.
I am thinking the DME Relay right?
What else if it isn't the relay?
Also this is strange , But the hazards are on but the switch is not pushed , when you push the switch in it does not turn it off.
This is new to today too. Where is that relay ?in the center console right?
DME relay is not in the centre console. It's in your fuse box (in the luggage compartment). It would certainly cause the symptoms you've described.
Doesn't explain what's happening with your hazards though. So the problem might be something else altogether. But the DME relay is a cheap thing to try.
Well I don't have a aftermarket alarm , but I do have the factory .
And that was it ,
Because the car was on a hill (my driveway ) and I disconnected the battery. Then reconnected it .
It immobilized it and turn the flashers on .
Once I powered it back up and locked and unlocked the door it fixed it .
Thanks!!
And that was it ,
Thanks!!
