964 Forum 1989-1994
Squeaky cluth pedal
Old Sep 6, 2009 | 02:42 PM
Low 964's Avatar
Low 964
Default Squeaky cluth pedal
Not used car for about a month, took it out today and clutch pedal is making a sort of rubber squeaky noise near full depression, it all works fine, could it be lack of use or the fact that the weather is colder ie harder seals etc???
Uk car
Old Sep 7, 2009 | 09:04 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Can you isolate where the noise is coming from? Is the squeak noise coming from the pedal assembly itself or from underneath the car? If its the pedal assembly, I'm thinking that you may need to grease/lubricate the pedal bushings.
Old Sep 7, 2009 | 10:43 AM
Low 964's Avatar
Low 964
Ta, I looked at the exploaded digram on the parts list, I guess a bit of lube may be necessary, just need to work out how to get to it!!!
Old Sep 7, 2009 | 10:55 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Removing the pedal assembly is not too hard, just awkward to reach. See this thread.
https://rennlist.com/forums/964-foru...al-solved.html
