rear screen leak/ how to fix?
Hi All, Last year I replaced my rear screen and seal, earlier this year while tracing an electrical problem which needed the carpets to be lifted (tracing immobiliser wires) the foam was found to be soaking wet, so I removed all of it! I can see that water is coming in from the rear screen passenger side (UK car) my question is how do I fix it! Replace the seal again? Or put some sort of sealant around it, do I need to remove the screen for this, I want to replace all the carpets but need this sorted first. Any ideas guys?
easiest thing is to remove the screen and see whats causing the leak. Maybe the seal was not seated correctly.
Once you get the hang of screen replacement, it isn't too bad of a chore.
