Lowering to RS ride height - Cheaply
Hey guys,
I am pretty close to locking down a deal on a C2. It has all stock suspension. I want to drop the car down to RS ride height, but since this is strictly a street car for me I don't really want to pop for coilovers or anything very expensive. I don't really care about ride quality as I am used to driving a GT3.
Can anyone tell me what is the cheapest way to attain a true RS ride height? I know the H&R greens get you close but not all the way. Has anyone done Green springs with after market spring perches?
For an example of desired ride height, this was my last 964 and I would like to get about the same thing on my new car.
Thanks!
Thanks!
Here is a shot of mine with H&R green springs set very close to RS height, mind you it did suffer from bump steer.
The critter in the foreground is my gran daughter.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Greens are slightly lower than reds IIRC. I installed Bilstein HD & H&R greens at the same time and also had it aligned to the spec given by Bruce Anderson in his book on page 206. If you want me to send them to you, please give me your fax #, and I will fire them off.
Given the perspective of "Cheaply": You can also use Bilstiens HD's and the factory springs which require you to shave a small bit off the rear factory stock springs... Although not as good as some of the other suggestions noted above, it is much cheaper and does achieve much of the goals of lowering the car. I did this on my C4 a few years back and had surprisingly good results although now have PS9's. For normal street driving, the factory springs are not that bad... You can't lower the car to RS heights using the factory equipment. You may want to research what each of the two components solve.
-tom
-tom
On the 993 any stock shock is dead after 30k miles and certainly after 10 years.
Im not sure how much better stock 964 shocks will be, but isnt fair to think they are dead after 15 years .. even for a daily driver 'beater'?
So, perhaps it does make sense to find new shocks as well.
