964 Forum 1989-1994
Magnecor vs. Beru
Old Jun 30, 2009 | 10:47 AM
crg53's Avatar
crg53
Default Magnecor vs. Beru
I have done a bit of price research, it seems the Magnecor 8.5 can be had for quiet a bit cheaper than the Beru; $443 compared to $599. The Magnecor add states that you can not install the lower heat shields, do anyone know the reason why. ?
Old Jun 30, 2009 | 02:13 PM
CWay27's Avatar
CWay27
And to say that I sold last year 20 sets of OEM beru for 225USD...... Wish I had ordered way more.
Old Jul 1, 2009 | 11:02 AM
Computamedic's Avatar
Computamedic
I believe Magnecor sell the lead sets for racing applications and, as such, they do not provide the grommets necessary for the leads to pass through the lower heat shields. Hence the recommendation.
Regards
Dave
Old Jul 1, 2009 | 12:16 PM
crg53's Avatar
crg53
Thanks Dave.
I thought maybe the plug connectors extended out too far, not allowing the heat shield to be mounted in its proper location. If it is only the grommets where the wires pass through the engine tin, that should be a fairly easy fix.
