FS: RS lightweight flywheel, disc, guide tube & bearing
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
Hi Guys - I have a used, in perfect working order, single mass RS flywheel with the ring gear attached and the pilot bearing installed, plus the longer RS guide tube and the proper clutch disc for sale that has life in it as well. I don't need it any longer and need to clear out the garage shelves to make room for baby stuff instead of car parts!!! ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
To install you can re-use your pressure plate & throw-out bearing if desired, but you will need the shorter flywheel bolts ( 9x $1.40 each) and new pressure plate bolts ( 9x $1.40 each). This flywheel makes revving these engines a whole new experience! A must for heel-toeing.
I'd like to get $500 plus shipping via UPS (which might be as much as $30 due to the weight). The kit from Paragon is $1595. Please PM me if interested.
