964 Forum 1989-1994
seeping oil line - replace?
Old Jun 20, 2009 | 06:18 AM
gchristofi's Avatar
gchristofi
Default seeping oil line - replace?
Hi all
My oil line from filter housing to engine (rubber-metal-rubber) that runs along the back of the engine is seeping some oil from the area under the heat shield. The oil is not even dripping so not bothered by that but just wondering if this pipe has been known to fail catastrophically?
Don't want to risk a blowout on this pipe if it has been know to occur. Any thoughts?
Old Jun 20, 2009 | 09:56 AM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
Not sure about a blowout, but it is time to replace it... one of the headers will need to come off to reach the engine side...
Oil leak
Old Jun 20, 2009 | 10:01 AM
Wachuko's Avatar
Wachuko
A few photos:
Some random photos of the work done.
Complete exhaust must me remove to get to the oil line.
Old line:
New line in place:
More photos of the new line:
Installing everything back:
Old Jun 20, 2009 | 11:06 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Jamie - Great pictures. Did you intentionally leave off the heat shield for the oil line flex area?
Old Jun 20, 2009 | 02:10 PM
gchristofi's Avatar
gchristofi
Jaime, thanks v much for the photos... ditto question about heat shield.?
Old Jun 20, 2009 | 04:37 PM
Wachuko's Avatar
Wachuko
I ended up taking out all the shields...
Old Jun 20, 2009 | 04:59 PM
dfinnegan's Avatar
dfinnegan
Professor!! You didn't!
Old Jun 20, 2009 | 05:46 PM
Wachuko's Avatar
Wachuko
Unhappy
I did... still have them. But looking at the older car and reading about those being only for noise reduction, and the fact that I get joy out of looking at the engine, I ended up removing more and more of them everytime I worked in the car...
Old Jun 20, 2009 | 07:16 PM
dfinnegan's Avatar
dfinnegan
That's a *great* pic! :-)
Old Jun 20, 2009 | 10:59 PM
964russ's Avatar
964russ
Check the SHINE!
Nice.
Old Jun 20, 2009 | 11:10 PM
pchak's Avatar
pchak
nice pix! Is that the "leaker" housing on the wheel well that Pete Zimmermann mentioned in his book as a problem 964 area ?
Old Jun 22, 2009 | 08:07 AM
boxsey911's Avatar
boxsey911
Gchristofi, is the oil line itself seeping or is the oil running down from the filter housing? My hose was wet with oil but it was all coming from the union. Tightening it up stopped it leaking.
Old Jun 22, 2009 | 04:40 PM
gchristofi's Avatar
gchristofi
Hi Steve
good call on that, will check before buying the new line :-)
Cheers
Greg
Old Jun 24, 2009 | 04:07 PM
JDD's Avatar
JDD
I have also left the sound shields off. Don't you like valve noise?
Old Jun 24, 2009 | 04:28 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
I wasn't referring to the sound shields. I meant the shiny cloth that is supposed to be wrapped around the foil line flex area. It is there to reflect the muffler's heat away from the oil. But if you want to run without, that's ok too. I was just wondering why? Its not heavy and its easy to install, so I decided to use it.
