Fast Clicking Turn Signal
I searched and could not find anything regarding my fast clicking right turn signal problem. Per Adrians book, I checked fuses 30-34, checked front and rear bulbs, checked the contacts and wires and cannot find why this is occurring. Any one have any thoughts here??
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Even if all bulbs appear good - remove/replace each one (lots of work but if the first few are corroded and dirty - odds are good one of them's presenting a low draw of current to the flasher relay - which requires a set current draw from the builb circuit to funtion properly. If ALL bulbs and sockets check out (and I mean REALLY check them all) then it's either an open circuit in one of the wiring runs or the flasher unit itself.
But Occam says bulbs/sockets.
RK
RK
I see by your Avatar that you have side mounted lights (behind the front wheel). Check that that light is flashing, likely burned out!
Super Moderator
Needs More Cowbell
Needs More Cowbell
You have a light out...could be bulb filament, socket connector, wire/harness, etc.
Start with a visual inspection of all lights (2 people help) and go from there.
Super Moderator
Needs More Cowbell
Needs More Cowbell
![offtopic](https://rennlist.com/forums/graemlins/offtopic.gif)
Occam (or Ockham) has a razor...
Pythagorus has a therom.
Ohm has a law.
IMHO, Pythagorus got screwed, I've never seen it wrong, I think it should be promoted to 'law' status.
