Garage -- Carpet vs Concrete
I have concrete floors in my barn. They are a bit rough and definitely contribute to moisture and rust.
Question, would it be an improvement to cover them with low-pile carpet? Or, would it make matters worse?
I'm considering whether to put the carpet out to the trash, or under the car.
have never carpeted a garage, but have epoxy painted all my garages. First thing I have done before I moved into my last thre houses. Makes a huge difference
IHI KING!
It depends on where the moisture is coming from. If its coming through the cement, then the carpet temporarily reduce the moisture until its reaches its limit (similar to a dry sponge becoming moist) and then the moisture would continue into the air. I think you would be better off using some sort of concrete paint or water sealent. I have an epoxy coated concrete floor and its wonderful. A friend had a damp basement and purchased water sealer and painted his entire walls and floor. It made a noticeable difference in the humidity. Not sure if your barn is air tight enough that this technique would do that same thing.
I would never put carpet in a garage, just think of how it would soak up any spill that WILL happen, I can think of oil changes etc...... also any little screw/washer/pin/spring that you WILL drop, disappears magiclly into that low pile carpet. I would paint it with a good garage floor paint, there are many brands on the market.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
If i used a barn i would treat the floor as above but also do anything possible to keep
rodents out. They can chew through wiring etc and cause havoc !! Happened to a friends 996
turbo & cost thousands $
My wife and I just purchased a house in North carolina and we are sealing the garage floor with Byer appoxy sealant. For a two car garage, with everything needed to paint it, cost around $75 from home depot, not too bad for the look and durability it provides.
I have used the Home Depot floor paint and it is OK. On my new home I used Benjamin Moore Industrial Floor Epoxy after seeing it in a warehouse with heavy fork lift traffic. That stuff is great - high gloss and nearly indestructable. Not cheap, but worth it.
I used to use indoor/outdoor carpeting under my car to catch the oil drips. You can usually go to lowes and buy the remnant for cheap.
Now that my car no longer drips (for the moment), I use the rest of the roll as needed to get under cars.
It has a rubber backing, but I do not think it will be water tight. You would be better of sealing the concrete.
I had a similar decision - though was initially looking at epoxy or industrial tile for the garage. I chose epoxy, and have enjoyed it almost maintenance free for the last 6 summers...
-Blake
-Blake
