Bleeding diff locks on an '89 C4
I think bleeding the brakes is generally considered removing any air trapped in the system whilst replacing all the fluid is considered flushing the brakes.
The diff-lock **** is indeed the right hand one ahead of the shift lever. This is nothing to do with bleeding or flushing the brakes. It is solely for the PDAS system and the method is as described above. People usually do the PDAS at the same time hence they are often referred to in the same context.
Neil
Neil
Regards
Dave
Hi,
having recently bought a 964 Targa C4 as a companion to my 993 Turbo, I tried to bleed the lock cylinders last night. Owning a PST2 (the original one) since a couple of years, I thought this would be a piece of cake. Well, I ran into exactly the same problem : car is a MY 1990 and PST2 will show the option bleeding cylinders but not allow me to go further, no matter what I try. Of course I had to call my wife and bleed manually with the swith on/off method.
Has there ever been an explanation to that problem ??
Alain
Alain
