Best spark plug socket?
Gang,
My factory tool kit seems to be missing the standard Porsche spark plug socket. What would be the best replacement, and what dimension should I be looking for (metric size, etc)?
Also, as to the best combination of tools for the job, what's your recommendation? I'm hearing differing views on swivel ratches and 4" versus other size extensions.
Thanks,
ketel
Thanks,
ketel
You want a 16mm (5/8 in) spark plug socket with a rubber plug holder from your favorite tool maker:
http://www.pcarworkshop.com/images/8...0190geolab.pdf
Hope this helps,
James
Hope this helps,
James
Hazet and Snap-on make magnetic spark plug sockets. The rubber plug style work, but eventually the rubber hardens or gets too dirty to work properly. I found I needed a 3/8 universal joint to get around the PS pump to get to #3 on the top. I don't think there are any metric size spark plugs - 5/8" and 13/16" are the common sizes.
Professor of Pending Projects
